Impressed by Sierra warranty
Brentathon
Sent back a defective impeller for my Alpha One (rubber loosened around brass hub), and they reimbursed me for parts, haul-out, and mechanic fees.
Nice to finally "catch a break" in this industry.
Brentathon
Re: Impressed by Sierra warranty
Impressive! Hope the replacement isn't from the same production run :D
Yeah, right? No, they assured me that they had an issue with a supplier, and it's been corrected. Maybe that's one of the reasons why they readily processed the claim.......it sure sounded like they were fully aware of the problem.
Brentathon
Just to update....they also sent me a box of 6 quarts of their gear lube, and an entire impeller, housing, and gasket kit.
Ayuh,.... Cool..... :)
wrench 3
I've been using Sierra parts for over twenty years and never had one fail. But it's nice to know that their warranty is that good.
Fishermark
Just to add another experience - in case someone says that is a good reason to go with OEM - I had the same exact thing happen to an impeller I replaced a few years ago. It separated from the brass insert. It was Quicksilver OEM brand. All I got was another impeller! :rolleyes: So it can happen to any manufacturer. (In fact it would not surprise me if ultimately they use the same supplier!!)
bruceb58
I would prefer to use OEM over Sierra. Nice that they replace defective parts but what about your down time and labor? What if the part fails in the middle of a vacation?
bruceb58
y oem over sierra ???
Personally, I had a bad experience with a Sierra water pump impeller. I know there were issues with the Sierra OMC bellows making it hard to get the u-joints past them. The price difference is not significant enough.
