Jon Boat Jim
Thread starter- Joined
- Mar 19, 2011
- 75
I have spliced in a small in-line fuel filter between the fuel pump and carb. on my 1983 7.5HP Evinrude. Is this an OK position?
The filter is a "see through" type. Gas does not fill the filter housing completely. When the primer bulb is pumped, gas partially fills the housing. I have tank tested the motor with this set-up and it appears to run fine......no problems at idle or high speed. Do you think that it's safe to take out on the lake?
