Re: In need of a Diagram (Engine) of Johnson35 outboard
Thanks rudeafrican... but the problem is that i don't know of wich year was the outboard manufactured so i don't know wich book to buy. But thanks anyhow.
Hi, Schembri.<br /><br />If you will supply us with the Model number, we can tell you the year.<br /><br />You would need the year to get a correct diagram, too.<br /><br />Good luck.
Thanks JB ...but the problem is that i don't know of wich year was the outboard manufactured. I need to look for the model number and let you know ...Thanks
The model number, which can be traced to the year of manufacture, is located on the engine.<br /><br />It should be on a plate on the transom clamp. If not there, then stamped into a round plug on the engine head.
