In need of Merc's 4.5 flywheel and prop torque specifications
dobrosailor
Can anyone help me with the proper torque for my 4.5 Merc flywheel. While your are looking, I probably should also have the torque for the prop. Motor is running great now, starts right up! Time to button her up for the final time.
Texasmark
On the flywheel nut you can www SAE fastener torque specs, find your size and go from there. On my 90 it was over 100 ft-lbs. So as a guess a 90 vs 4 is about 20:1 so about 5-10 ft lbs. You probably have a Woodruff key in the flywheel and the two should hold unless you hit something with your prop at WOT which possibly could force it to slip out of position. A distorted Woodruff key and hard starting would attest to that.
On the prop, same thing or when grasping the prop in one hand and wrench in the other, good and tight, which is defined as uncomfortable trying to hold one prop blade with one hand.
