ineedacottage
- Joined
- Jul 12, 2006
- 69
and part of the gasket was stuck on...I used a utility knife blade to clean as much off as I could - how clean does this need to be?
I have some 3M Scotch-Grip Rubber & Gasket adhesive to apply to both sides of the new gasket...
Also I had to loosen the black ring (I think it is the stator?)...is there anything I need to watch out for when tightening it back down?
And one more (how can you tell I've never done this before
)...When I pulled the flywheel the woodruff key stayed in the shaft... is this normal? I just need to be careful to line it back up when I re-install and torque the flywheel?
Thanks a lot for your help!!
I forgot to add that it is a 1990 90hp Johnson.
