Robbabob
Thread starter- Joined
- Jun 5, 2009
- 678
The new to us 1990 Carver Montego 32' (twin inboards) is in really great shape. A couple of moderate concerns to take care of in the first year, one of them being to tighten the port screw packing nut. My surveyor tells me there should be no drip when the shaft is not spinning, but a drop per minute is still no big deal (not enough to sink the vessel if monitored at least once a week/month; this one is at maybe 6 drops per minute.
In my quest to fix things in my control, I took a pipe wrench to try and get a little turn on the nut... after crawling in and contorting my body, I thought I had a good position to make a little progress. As soon as I put any force on the nut, water squirted into the bilge. I thought maybe I was putting an uneven force on the nut, so i adjust the wrench and went to it again. Again, water squirted at a fast enough rate to concern me, "if I mess this up and sink her in the slip....!"
Each time I quit putting pressure on it, the drip would return to a rate of about 6-10 drops per minute. Maybe a little faster than before I started. The next day as we head out on the lake, I turned the bilge pump on manually and got maybe a couple gallons out. Later in the day, through the following day, nothing pumped out, and a visual back at the dock confirmed there was minimal water present.
FINALLY THE QUESTION
Should I expect the packing to allow water to squirt while I'm trying to tighten it? I realize the material is not like a 1-piece Teflon packing that actually squeezes on the shaft, but it was scary to think the packing would allow a squirt like that.
I'm probably over-concerned and need to just get in there and give it a good hard go of it. What say you? Else, I have a pro do it... and nobody wants to pay a mechanic for an easy DIY fix.
Thanks!
Thanks!
