inboard
mikalsmess
i have a 96 marada inboard and i took a screw off the side of the upper end of the prop and cant get it to go back on. no threads there,
CheapboatKev
Re: inboard
maybe they could help if they knew what OD set up you have? Merc Alpha? OMC? Volvo Penta?
Bob_VT
Re: inboard
Did the prop slide up or down on the shaft?
Re: inboard
Ayuh,... My Guess is, He's got an OMC Cobra,+ has found the screw that does Nothing.....
mikalsmess,..
At this point,... You've gotta drop the lower unit, find the little piece with the threads in it, put it back up where it belongs, reinstall the screw,+ Never, Never remove it again....
Btw,... You Don't have an Inboard,... It's an I/O,.. An OMC Cobra to be exact...
