Re: Inconsistant spark on bottom 2 cylinders? Need some help
A 2.4 ECU will not run on a 2.5 as fuel curve in mapping is different. Look on the heads and get casting number to see if a 2.4 or 2.5L. Also
You bought what you think is a 2.5 but it has a 2.4 ECU, this could be a serious problem.
The prior owner told you how fast the boat USED to be, what didn't he tell you? What wrong parts he installed?
Verify what you have before you do anything else.
Find the soft plug on the block, make sure that number string is the same as your serial #
Find casting #'s of the block and heads, repost them here so we can make sure of what you are working with.
Also post what prop you are running.
