Pete Sauberlich
Thread starter- Joined
- Oct 13, 2023
- 10
Looking for the best way to boost the power of my proV 150. Any suggestions are greatly appreciated.
5500 rpm, 58.7 mph, 23p Yamaha stainless 3 blade. On an '89 Ranger 364v. Some research I have done said swapping the carbs out for 220s and upgrading the reeds would be the way to go.What's the WOT RPM's and your top speed? What prop are you running?
What signal?swapping to bigger carbs means the signal other than WOT is lost and drivability from idle to mid-range suffers.
Time to understand how a carb works, Bernoulli's principle, and what a carb signal is.What signal?
Yes, from what I read the tuner is what is most responsible for restricting the power the motor could produce.to get more hp you need to get more fuel and air into it at the proper ratio, and you also have to let that extra exhaust back out, so would probably need to modify the exhaust system also
Right now prop to pad is 3.25. Was thinking about trying a different prop also.Your speed is not bad for a 150 on a Bass boat. You might calculate the slip, which will not be much. Maybe raise the motor a bit to lower drag.
