Condor1970
- Joined
- Jun 9, 2014
- 195
I've had a couple posts before, of my Alpha One outdrive havnig some issues. I puleld the lower to grease the U-joints, and they are good. Greased shift cable, and it operates smoothly. Changed out gear oil, and tried running the engine. The problem is, when the engine is running, I am getting a clacking/knocking sound from the lower. I thought it was the gears again.
I pulled the top cover, and pulled the top bearing. It isn't that bad. It has some pitting in the cup, felt a smidge gritty, so I will replace anyway. The thing is, after draining the lube again, and thoroughly inspecting all the gears, I can't figure where that noise is coming from. The gears look good. Yet, I found some more shavings in the oil, and on the magnet when I drained the oil again. With those shavings in there (though just a few), I should be seeing damage to the gear teeth, yet there is basically none.
I am suspecting a shift cable problem. I honestly am not an expert on outdrives, but that's the only thing I can think of. Maybe it's trying to lock up when I run the engine at idle or throttling up in neutral? My plan is to go through the whole process of adjusting the cables, and also to pull the lower for an impeller change this weekend.
When done, I want to flush the entire outdrive to remove any filings or debris inside. What do you recommend is the best way to do this? I was planning on using some kerosene, or lamp oil, to do this, since it's what normally is used for flushing any gear box. Is there anything wrong with this?
Also, is the noise I'm hearing most likely a shift cable issue, since I honestly am reaching my wits end. I have no idea what else could be causing this. If a shift cable is slightly off, what would I expect to hear from that? I would think I should see the prop trying to spin, but it's not.
