Re: inductive tach how good
If the lead is only 6' long, you use 1 to 3 wraps around the # 1 cylinder plug wire on newer engines. The older engines could require up to 5-7 wraps to work because older ignition systems don't have the same high tension voltage as newer outboards. If you extended the main sheilded wire, it must be done very carefully with EXACTLY the same tiny sheilded wire with a tiny sheilded connector. You cannot extend the wire that is soldered beyond the shielding. In addition, if you extended the wire, you will need to make at least 6-7 wraps to make it work. Mercury makes 3 models of these "Service Monitors" and you must make sure you have the rite one for your motor.(They are actually made by "Tiny Tach" for Mercury's specific neeeds)<br /> I use one of these on my new Merc 40 HP "micro bass boat" and had to make the cable longer and the other aforementioned mods to make it work. If you need more info let me know and I will point you to the proper places to obtain the wire and connectors for an extension.<br /> The little tach works fine and updates fairly fast....I have no complaints....Reads hours when the engine is off
