FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a small johnson i need info on. M# FD-17B SN 2374969<br />and also i have a 125 hours evenrude that i need the year on M# 125 183C sn e04579 thanks
Morning Brandon.....<br /><br />The FD-17c is a 18hp from 1963.<br /><br />The 125183C is a 125hp from 1971.<br /><br />HMMMMMM.....my explorer seems to have taken a time out...can't find the info you may need. If one of the other guys don't post, I'll throw some more info in when I get to the shop. The books never take a time out..... <br /><br />EDIT: Little info:<br />18hp....plugs are J4C gapped at .030<br /> Fuel mix is 50:1<br />Standard ignition....points/condensers..Points gapped at .020.<br /> Gear lube..hi-vis.<br />Water cooled....has an impeller and t-stat.<br /><br /><br />125hp...Electric shift.<br />Plugs are a L76V gapped at .030 but engine will idle better with a .040 gap.<br />Fuel mix is 50:1<br />Ignition system is 12V driven distributor. Amplifier is on the side of the engine. Points under flywheel.<br />Gear lube is a premium C lube or a lube which is made for an electric shift.
OBJ<br />Not to doubt your wisdom, but weren't 1963 model motors 24:1 and the switch to 50:1 started in 1964? Seems to be a little confusion as to when the changeover occurred and maybe you can straighten me out.<br />thanks
You are possibly right angus. I can't remember what year the change over took place....it was in this general time frame. Maybe Dhadley or one of the other guys can set us straight. <br /><br />Thanks for bringing that up....
"If your motor was alive when JFK was, mix it 24:1. If your motor doesn't remember that terrible day, mix it 50:1"<br /><br />This was a sign on the counter of a shop I used to frequent as a kid in the late 60's. I guess old Willard, the owner, was tired of answering the question and show his Irish.
If you're looking for confirmation angus63, I'll provide it. A good example is my '64 28hp factory service manual, which states 1 pint for 6 gallons (50:1) for the '64 outboards, but has a note to keep running '63 engines at 1 quart for 6 gallons (24:1) after break-in.
