Info request for Johnson 3hp JW 16
CN Spots
Model# JW 16
SN# 2036847
Is there a site somewhere with history/info on this motor? I'm looking for the year/s of manufacture, oil/fuel ratio, points gap, clones (Evinrude) and any known Achilles' heels. Thanks.
spots
Scaaty
Re: Info request for Johnson 3hp JW 16
Have 3 runners...none in my book. Use 24/1 on oil. .020 points. I'd slap a new set of coils in it...go bad with age..20 bucks apiece...parts available, always something ebay too.
CN Spots
That was fast! Thanks guys.
spots
Paul Moir
Additional links:
http://outboard-boat-motor-repair.com/ (seems to be down. Check that site, there's a parts manual and owner's manual on it)
maxrules.com/fixtuneitup.html
http://www.faculty.mcneese.edu/jbailey/lightwin.htm
http://digilander.libero.it/OLDMERCS/storia/lightwin.htm
http://old-omc.de/index2.html
Stick with 87 octane gas and TC-W3 outboard oil at 24:1 and it'll live a long time. Hopefully you've got the intake silencer and the screen that goes over the carb - a lot of people removed them thinking it would make the motor go faster. It just makes them run bad.
There were few changes over the years and not many significant ones (excepting the folders of course!). Lightwin was the Evinrude version. In later years it got developed into a 4hp, then a 4.5 and then back to a 4hp. It's probably the best small engine ever built.
Other than the coils and related problems like wobbly armature plates (same for all the '50s-early '70s 1 and 2 cylinder J/E engines using the universal magneto), common problems are dented gas tanks, filthy carburetors, and if it was used a lot in salt water there is sometimes a tricky cooling problem. If the cooling system was neglected and the engine never flushed, you could get a build up of crud that would block the cooling to the head and cylinder jackets, but still allow water through the block.
Scaaty
Thanks for sparking my old brain...I also have a Belgium Rude too besides 3 JW's!. Rude I got for a song, and of course, it had a bad coil! So thats 4 "Weedless" motors.
Think I need to run a ad in Minnesota craigslist, and make some Northwoods duck hunters happy. Getting to much stuff (again!)
CN Spots
That old omc site is cool. Thanks Paul. I love those old ads.8)
spots
