muskyfins
Thread starter- Joined
- Jun 7, 2012
- 587
Been battling a light problem on the truck. Driving me freaking crazy. Can you guys help?:frusty:
Symptoms (tested with brand new magnetic lights)
Headlights off-brake lights good
Headlights on-brake lights good
Headlights on-no left turn signal/turn signal on truck only lights up and does not blink
headlights on-right turn signal ok
headlights and brakes on-no turn signals
headlights off-turn signals not tested recently (no data)
I'm also pretty sure there is an issue with the fog/daytime running lights.
Is it possible that if one or both of the DRL's are shorted, there is too much load on the system to flash the turn signals? Or is it redirecting so much voltage that there isn't enough to run the turn signals?
