Re: ingnition resistor wire/where is it
Any engine with points and condenser must have a resistor to lower voltage at coil from 12v to 8-9v. This low voltage,extends point life, greatly.<br /><br />Your ignition is wired - Purple 12v wire from main wiring harness,to choke on carburetor. Purple resistance 8v wire from choke to + side of coil. <br /><br />Quick fix - run a new wire from choke to + on coil. Install a marine bar resistor in this wire. They are cheap $6. Any marine parts store has them.<br /><br />Or - run new wire, and install new coil with Internal resistance written on side of coil. Such a coil will put out 8-9 volts.<br />Your present coil should have external resistor required, written on the side of coil. <br /><br />There is a second wire to + on coil. It comes from starter slave solenoid. It should be purple with yellow stripe.<br />When cranking engine, it will give you 12v to coil for a hot start. <br />When key is released, you run on 9 volts.<br /><br />I have wiring diagram, but I don't know how to post it to this site.
