Inherited Evinrude trolling motor need info
mikewright3747
I have inherited an Evinrude trolling motor (model # BF4PH99) and am not sure if is a 12 or a 24 volt system?
Huron Angler
Re: Inherited Evinrude trolling motor need info
Do you have photos? Also do you know how many lbs of thrust it is? Most over 50lbs are 24V, not real familiar with Evinrude trollers though, it's probably from the 70s and there aren't too many around these days.
OMC flirted with electric and then got away from it and stuck to internal combustion(Minn Kota had a superior product I believe).
That being said, if it works it probably will be a good one to use:)
mikewright3747
Not sure but I will look to see when I get home
