998cc
Thread starter- Joined
- Mar 30, 2013
- 159
Hello All. i have been posting here since picking up a new-to-me boat in March of 2013. The issue I have now is an exhaust leak the I traced to the head/manifold joint which is leaking; yes, the bolts are tight and a new gasket was used on motor assembly (rebuilt motor). The head was done at a reputable machine shop, so I can only assume the manifold is warped. The manifold is from a 1978 donor engine. The question is if the manifold can be successfully re-decked at a machine shop, or is a new manifold in order?
Thank you.
Russ
Thank you.
Russ
