inline 6 not firing on 2 4 & 6
Raider316
I have what I believe is a 1980 Mercury 90 hp inline 6
I have been having a problem with it idling fine in my yard but once I put it in the water and shift it into gear it stalls. Then it floods out and will not start.
Carbs have been rebuilt
Anyway I checked the plugs based off of advice from another thread and found that 2, 4 & 6 cylinders are not firing.
What could be causing this?
Thanks for any help.
Laddies
Banned
Re: inline 6 not firing on 2 4 & 6
You either have a bad switch box or half the stator is bad. Swap the red and red/white and the blue with the blue/white and retest for spark if it moved to the other 3 cyls it's a bad stator if it stayed the same it's the box.
Raider316
Thanks I will try it. Wires running from stator seem kinda soft anyway
cannonford57
going with laddies but probably gonna be a switchbox
Raider316
Thanks for your help. It was the switchbox. Nice to finally have found the problem!
