Inline six
sms2112
I just got a Starcraft with 90 hp inline 6 ,hasn't run in a couple yrs so I'm going thru it oils , grease compression tomorrow . anyway IF it needs rebuild is it worth it or just move on . I'm hopeful it won't need it as the old timer "not this one" lol seemed to be on top of everything . Thank's steve
Vt MercMan
Replace the impeller. They lose their ability to produce adequate water pressure as they age and the result is inadequate cooling for those 6’s.
Youre on the right track with checking the gear case, etc. Always use good (preferably Mercury) 2-stroke oil and quality gas - non-ethanol if you can get it in your area.
jimmbo
Looks like an 86, I think that or 87 was the last yr for the inline 6 90hp. RPM range at WOT is 4500 - 5000. Stump pulling low end torque with those engines. One thing to do if you want it to live on today's ethanol gasoline, is to plug the 'Back Drag' feature on the carbs. Easy to do. On the top of the carbs, there is a black hose that goes from the fuel bowl over the top to a fitting on the carb throat. Remove the hose from the fitting on the fuel bowl, put a small ball bearing in the hose, the reinstall on the fuel bowl. That will keep the fuel-air mix from leaning out too much
sms2112
Thanks guys, will do. I found a 79 , 140 hp tower,original owner for $600 he said it runs but developed a "tick" going to look at it for my first complete rebuild project on boat motor. I worked on all my 60's-70's cars so how bad could it be ? Famous last words lol at least I won't need a staging and a come along to pull it.
The work isn't bad but the parts can add up fast. Marine hard parts are not cheap. Personally, I wouldn't bother with a $600 builder. With the change from crankshaft to prop hp ratings between those model years the 140 might not have as much extra jam as you think. I had a mid 80's 90hp inline, a solid running motor. Is there a reason you're looking at this 140 instead of your 90?
That 140 was de-rated to a 115HP rating. The changeover from distributor ignition to ADI ignition occurred in 1979, so that 140HP motor could have either one. You want the ADi ignition, as it is used on much newer motors, and parts are cheaper.
If it were me, I would look for a late 90's V6 motor to replace that IL6. You should be able to get one for $1K or so. The V6 motors are much better, as they have better power from idle all the way up to max RPM.
My Merc 1500 IL6 had little power until RPMs hit 3000. Of course, then she would accelerate from 30 MPH to 50 MPH in a few seconds.
havoc_squad
Hmm, I'd say the following about that:
Customer: I paid THIS much for it take stupidly forever to get to WOT speed?
Engineer: They wouldn't let us make it OUR way, I told them it was a dumb idea.
Marketing: This is not a design flaw, it's one of our key great FEATURES, it builds anticipation for the driver when it will reach blazing speeds.
jimmbo
That was the nature of the beast, wild port timing and big carbs made for that type of peaky power band. My experience with the inline 150, was it would idle very nice, but from 2000 - 4000 it was a cantankerous thing, once it hit 4000, things happened very fast and it had a lot of power.
A V6 150 is far superior, when it involves low end torque, and burns less gas despite a 22% increase in displacement
As for the 140 becoming the 115. Maybe, maybe not. The 140 had a WOT range of 5300 - 5800, the 115 was always 5000 - 5500, prop or crank rated. Carb calibration was different between all three engines.... In 1984 Mercury started using a piston with a lower dome, How that affected the HP, ???? My 84 115 gave me a 11mph increase in speed over my 78 90, so that difference suggests a 50hp jump from the crank rated 90.
Jimmbo, I had the Merc 1500 on a 16 footer with a 21P prop. Getting on plane with a skier took a few seconds, however, after the RPM reached 3000, if I did not pull the throttle back, the skier was launched out of his skis from the acceleration.
My current Merc V6 on the same boat has a much more consistent power band. Much easier to drive....and more power across the RPM range.
I still vote for the V6.
sms2112
Hi and thanks for replies . Talked myself out of the 140 brainstorm lol . As for the 90 I did the gear oil, psi test was 128 130 all 6 now I'm going thru the fuel system clean up and then a step by step testing all ignition components . Trim is working and took apart transom steering cleaned regreased rod and heated and repacked cylinder grease that was like clay. I am shopping for another motor but not rushing it, it will find me.
sms2112
Well can't register it without title from original owner even though he registered it till 2016 without ever getting a hull number or title he sold with bill of sale that owner never registered it and sold to me bill of sale so 2 ppl need 2 apply for title before i even get one. Not worth the trouble so it's off to aluminum scrap yard.
sms2112
Got lucky found a titled shell for $300 same size took the title and told him he can scrap it . lol Both are happy I got title he got extra cash for scrapping it .
jimmbo
Some of your States have some real Anal rules about buying, selling, licensing, of boats and engines. Here a boat gets licensed on initial purchase, and the number assigned is for life and just a bill of sale is needed for transfer. Engines are never registered or titled
Here water vessels are Federal jurisdiction, and the provinces are not involved, removing the roller coaster variations of rules
sms2112
My daughter goes to college next yr RSOA near Ruskin or SCAD in Savannah and I'm outta here with her lol
