input shaft installation
affa
Hi<br />Ive replaced the oil seal on the input shaft on my alpha one, now Im having trouble getting it back on the drive, I cant get it longer in then the threads on the upper drivehousing, are there any tricks someone can recommend?<br />Regards<br />Affa
TwoBallScrewBall
Re: input shaft installation
More Muscle. :) <br /><br />New orings are hard to get in most of the time. I replaced the o-ring seals on the upper-to-lower seal on my Cobra, I'm close to 300 pounds and even with my full weight on it and plenty of white grease, it still took everyting I had and plenty of twisting and wiggling to get the two case halves back together. <br /><br />Someone might have a trick for that particular job, but in general, the good part is that the new ring will seal better, the bad part is that it seals better because it's tighter so it's a b!tch to get back on. ;)
affa
Thanks Steve<br />I Got it on, I had to punch hard though<br />thanks again, tomorrow Im on the sea<br />Affa :cool:
outboardguy
It's better to pull the assembly back out and then heat the snout with a propane torch.Then install the driveshaft, it will slide in freely.
affa
OK Thanks!<br />You mean to heat the hole in the upper drive housing where the input shaft sits then?<br />Regards<br />Affa
outboardguy
I just heat it from the outside so that it will expand the few thousandths of an inch it takes to get the shaft in.
affa
Ok Thanks for the tips!<br />Affa
