Re: Inside tire wear!!
All we know is you have an all aluminum deck boat that seems pretty heavy and that the trailer tires are worn on the inside. No boat name/model, no boat weight, don't know if it's an I/O or outboard, don't know how big (HP) the engine is, have no trailer weight capacity info, no tire size, and we can't see your rig so I think it's safe to say we have no idea what the problem is. Could be too much boat for too small a trailer or simply that a previous owner routinely snagged curbs going around corners and the spindles are bent. Get the rig weighed and then look at the tire sidewall for the maximum load capacity. Then look for an ID plate on the trailer tongue or somewhere on the frame that indicates what the trailer load capacity is with the size tires you have. Without data we simply can't help. You can pull a hub and check the spindle size. 1-1/16 inner and outer bearings means you have a 2000 - 2200# trailer. 1-1/16 outer and 1-3/8 inner bearing means you have a 3500# trailer but only if the springs and tires can support that load.
