Re: Depth Sounder - power accessory??
Thanks all so much for your advice! SeaHorse - your advice was awesome! It TOTALLY worked - no headache waiting for it to dry in place! 8)
Ok, so here's my next question:
I installed it all... and it powers on (yahoo)! But (isn't there always?) I hooked it to my fuse panel but the opening that I used keeps it constantly powered ON. I fear that my battery will drain fast, backlit this thing is Humminbird!
In the Humminbird manual it reads "if the unit is wired through a fuse panel, make sure that the panel is powered, as accessory fuse panels are often controlled by a separate switch, or even the ignition switch of the boat".
This is a confusing statement to me... is this saying, hey stupid, make sure it's hooked to the ignition so that it turns off when you turn off your boat? And if this is the case... how do I do that? THANKS
