Broncojim1126
- Joined
- Jan 28, 2012
- 18
Well I Have never worked on boat wiring before, so please bear with me.
I have a 2004 Hurricane Deck Boat, With a Yamaha 115 4 stroke. The boat doesnt have an hour meter, so I got one the other day and I would like to install it. In the instructions it said to just take power from a source thats switched when the key is in the run position or ground thru an oil pressure sending circuit.
Ok the back of the gauge has 2 flat terminals. Where can I pull power from that wont cause me to go insane trying to decode the spagetti mess of wires behind the dash? Do I just pull a hot wire off of something, cut the wire then re-solder a terminal on that line with a little extension line to go to my hour meter? Ground to the common ground strip?
Heres pictures of my under cowl.
What is the antenna looking thing and what are the 2 terminal strips?
Back of gauges
Front of Gauges
Back of gauges
Front of Gauges
