Install & wiring for trim gauge
copake
Hello, long-time reader, first time poster.
(and yes, I did try the search function first.....)
My new-to-me Bayliner Capri doesn't have a tilt/trim gauge, and I'd like to install one.
First of all, I did just have extensive (but normal -- bellows replacement, raw water pump, outdrive lube) maintenance done by a trusted mechanic. There are the two sending units on the outdrive -- one (port?) limit switch sender for the tilt, and the other (starboard?) for the tilt angle. The mechanic did adjust the limit switch properly so the drive can't be over-trimmed.
Presumably the tilt angle sender wires are just terminating someplace in the engine bay. Can I simply run these to the dash, and wire in a tilt gauge? Obviously will require drilling a hole someplace on the dash. I assume any guage will also require power, which I could tap into behind the instrument cluster?
Thanks for any guidance.
Silvertip
Honorary Supreme Mariner
Re: Install & wiring for trim gauge
Trim gauge requires just a single wire from the sending unit on the drive, up to the "S" terminal on the gauge. +12 volts, ground, and the light connection can be obtained from any other gauge on the instrument panel. The gauge will then go active anytime the key is on.
copake
Terrific, thank you Silvertip.
