Installed New Tach; Lost Power to Motor?
jskise3
Are there fuses somewhere? What could have happened? Put old tach back in and still no power to start, trim, etc. please help
Daviet
Re: Installed New Tach; Lost Power to Motor?
Most engines have a fuse in the system. It would help if you would post the model number so that we knew exactly what engine you have.
WernerF
1985 150hp I guess. Yes there is a 20A fuse. It's in a red bullet-shaped thing in the harness on top of the engine. One red and one red/purple wire goes to it.
jskise3
Sorry... 85 Johnson 150gt... Can't find that fuse on top of the engine?
jskise3
Found it n that fixed it... Sadly tach still doesn't work? It charges the batteries, it can run with the hot terminal off... So rectifier/regulator is good... Plus a brand new tach? Why won't it work???
gm280
Don't assume that the rectifier is good unless you actually tested with a meter. It can be your problem for sure. If after you verify the rectifier is good and your tach still doesn't work, check the wires for any breaks or insulation rubbed off possible shorting the signal going to the tach...
175se
also if you have surface mount control check to see if it unplugged if that's how its fed.
Fed
If your 'hot terminal' is the battery positive terminal then it's likely you have cooked your rectifier.
The engine charging system has nothing to do with the ignition system.
