michaelrj9
- Joined
- Jun 25, 2006
- 16
Hi all,
I have a few questions about installing a 3000 continuous 6000 peak inverter the correct way.
I am Installing 2 6v trojan deep cycle batteries in series for the inverter which will give me almost 9 hours of operation at a 25 amp draw.
Also will be using a battery isolator.
1.)Do you have to use a "marine inverter"
or can you use a standard one as long it is fused properly. and the battery isolator? or will the coast guard not aprove it?
2.)It says 2/0 cable no longer than 3 feet long.
Does anyone know a online calculator that would tell me what size wire i would need if I need to go more than 3 feet. more like 10-15 feet.
3.) I would still like to have this battery attached to the "battery switch" so it can be easily turned off in needed to be.I will need to use the 2/0 or larger for this correct? Will the "battery switch" hold that much power?
Am I missing anything?
Thanks
Michael
Thanks
Michael
