installing a impellar on a 1987 125hp force chrysler model 1086
hays
i bought this motor from a guy who loved to paint the motor with epoxy coatings. i've taken off the coatings, found the vent / fill and drain screw (drain screw below torpedo ) what i want to do now is install a new inpellar to be on the safe side of maintance. it's different than my black max. where do i start to get at it. thanks, hays
jerryjerry05
Re: installing a impellar on a 1987 125hp force chrysler model 1086
Follow Franks instructions.The bolts that hold the WP housing need to be tourqed.
40in #s I believe.Check your manual.
Over tighten will cause leaks.
