Installing a long shaft outboard on a short transom
Andyfender
What do I need to install an outboard with a long shaft on a transom that is made to take a short shaft outboard?
Andy
ondarvr
Re: Installing a long shaft outboard on a short transom
Nothing if you're not concerned about performance.
If you want it to work correctly you need to raise the height of the current transom or use a jack plate.
carbineone
This is what I did.They are aluminum plates and it turned out really strong I believe,,,,
Andyfender
Very nice! Where did you get the material to make this?
Andy
ezeke
I made the one in the thumbnail with four pieces of salvaged angle aluminum. It has the benefit of being adjustable, up and down. The backer is 2 pieces of 3/4" plywood glued together.
Note that the angled pieces are longer than they appear.
If you want to use aluminum plate, you can usually find sections on Ebay. 1/4" is more than adequate if you make with wood sandwiched between. http://cgi.ebay.com/6061-T6-Aluminu...tem&pt=LH_DefaultDomain_0&hash=item4aa0db5af3
bktheking
I did the same with mine, put the plate on yesterday, had to raise almost 2 inches cause the transom wasn't tall enough. Had a local welder make it , it's all tig welded, pretty cheap to do and strong as can be.
carbineone
The aluminum you can pick up at a a lot places..I was fortunate to have a friend that works at a local plant so I was able to get it cheap.Just call some local manufacturing places and they may have some small scraps.....Bruce
