Liquid_force
- Joined
- May 7, 2003
- 318
Doing a little brain storming here.
The process of actually attaching it should be simple enough.
I'm planning to simply drill a couple 3/8" holes through the tower and insert some SS studs which will serve as the pivot point.
The hang up I'm worried about is the point at the outer edges of the canopy rubbing against and/or not clearing the inside surfaces of the tower.
Would you think just being sure the width of the bimini is on the narrow side, so the attachment poles have to be pulled slightly apart (top narrower than base) would be enough to make it work?
The other option, that I'm trying to avoid, is buying a bimini with a taller frame that would mount, as usual to the surface of the deck.
