bob johnson
- Joined
- Feb 25, 2009
- 4,306
I have a one battery boat now. I am adding a second battery to mainly run a winch I am installing. the boat is a 21 ft center console and the battery is in the middle of the boat under a seat in front of the console. So i have to climb aboard and open the lid to access the battery for charging.
I bought a Guest 2 bank charger 10 amp. I want to install the charger and an extra battery, as well as a battery switch.
I also want to install a plug to the charger in an easy access spot so i dont have to climb into the boat to plug in the battery charger.
so looking for a diagram
I want the switch to be able to use the extra battery in case i needed more UMPH to assure starting the outboard!!!
the extra battery probably wont be used much and i only see it being connected to one device( the winch) when the battery switch, has the batteries seperated.
i use the boat in a bitter cold salt water enviroment for several months.
I have a book titled "The 12 VOLT BIBLE for Boats" and it shows a weird diagram for the onboard charger hooked to an isolator( that also has a wire to the alternator) aand the the isolator is connected to the battery switch, then the switch connected to th batteries.
dont understand the isolater.. and I have an outboard, so dont know how Id connect to the alternator( i assume that diagram is for inboards)
hope to hear from you guys.
I have the boat wired nicely now and a fuse panel so i need to keep the battery where it is now..in the center of the boat
PS: can the BATTERY SWITCH be set off away from the batteries?? like where I can reach while the boat is still on the trailer? or will that be too much of a draw running all those long leads??
thanks
bob
thanks
bob
