eavega
Thread starter- Joined
- Apr 29, 2008
- 1,377
Hi
So I am wanting to install a fuel water separator on my 1988 Mercruiser 3.0 L. Silly me thought these things were standard, and I just ordered the bracket and filter kit, as well as the fuel hose barbs connections. I got everything 1/4", which I now know is wrong. So, my problem is that I can't really tell what hose size I should be using. The fuel line from the tank to the fuel pump has a bunch of markings on it designating that it is marine fuel hose, with some compliance numbers, and right at the end the hose is marked 0.5" I think, its not terribly clear. Anyway, I measured the inside diameter of the line, and it is a bit less than 1/2", which leads me to believe it is actually 3/8" id. Dos this sound right? The manual doesn't specify the fuel line diameter size, it just says that it should be a minimum of 3/8", but larger if its a long run. I can't find a 1/2" port fuel water separator bracket, nor can I find a fitting that has the 1/2" barb with 3/8" threaded fitting. Will I be all right using 3/8" fittings/bracket? I'd rather replace the four feet of fuel line from the tank to the fuel pump than have to hunt around for what are apparently hard to find fittings.
Opinions?
Thanks for any information you can provide.
Rgds
Opinions?
Rgds
