Installing Impeller on 1992 MerCruiser Alpha One Gen 2
ShaneCarroll
First off, let me say thank you to all of the helpful members of this website. I can't say enough about Don S, and all the help he has given me (starting issues, pulley, etc.)
I would consider myself somewhat mechanically inclined, but my problem is as follows:
I can idle all day, and the temp stays normal, after going above 1/2 throttle, the temp creeps up to the higher end of the tolerance zone. Being cautious not to blow the engine, I slow down at this point or shut engine off completely. (Only happened on one outing, noticed halfway to destination, and on the way back.)
I just recently purchased this boat, and do not know when the last time the impeller was changed, but I believe the impeller to be the issue. A mechanic told me to replace impeller as well as thermostat with I believe a 140?
Is there a forum that I seem to have overlooked, or any links to installing an impeller? It seems easy, but I want to do it right, instead of worrying about a new motor.
Thanks again, and once again, I feel indebted to the people who constantly help: Don S, chiefalen, as well as the others. Thank you all very much.
Re: Installing Impeller on 1992 MerCruiser Alpha One Gen 2
Ayuh,...
There's Detailed Instructions in the Alpha 1, Gen.II shop manual found in the Adults Only sticky...
ShaneCarroll
Thank you all for the help, Bond-O, I found that section, and it helped me tremendously. I can't believe I overlooked it!! Anyways, for the first time, everything was a breeze until I went to put the lower unit back on, it was puttin up a fight.
Once again, thank you all.
stonyloam
Been there, done that, learned my lesson. From now on pulling the outdrive and servicing it on the bench. Also gives you a chance to check out the bellows, universal and alignment.
Revenge
Once the water pump and seal housing has been removed, is it normal for the drive shaft to move slightly side to side? Or is there a bearing needing replacing?
Ayuh,... It's Unsupported,... Put it back together,+ it'll be Fine...
