imported_scott_r
- Joined
- Mar 23, 2007
- 25
Having trouble installing a rebuilt lower unit on 1980 115 HP Mercury outboard. I have a 3/4" gap between lower unit and driveshaft housing and don't want to start forcing it. The prop shaft splines seem to be aligned, as I can turn the flywheel clockwise and the prop shaft turns. The water outlet tube is aligned into its guide sleeve. The shift shaft does not appear to be engaged yet, or at least the shaft on the lower unit doesn't turn if I move the shift control lever. Do you have to apply a lot of pressure to get the driveshaft fully inserted into it's coupler on the powerhead or am I missing something else? Suggestions and cautions?
