Installing new starter
cucinae5
i need to buy a new starter for my 1999 Merc Force 120 HP. It looks really simple to take the current one off and install the new one. I see two long screws with bolts, and one at the base connecting a wire. Is it that simple?? Is all that is need is to undo the top two bolts, and the bottom, then install the other one.
do i need to do anything else with it once i replace it>
roscoe
Re: Installing new starter
Thats pretty much it, like changing a light bulb.
kend301
Check the bottom of the new starter there may be a threaded hole for an "L" bracket to help support it still just one more screw if it has one . If it does take the bracket loose from the block then remove top nuts and starter , transfer bracket , leave it a little loose on starter so you can recenter it to bolt to block then tighten up on bottom of starter.
john from md
Most of the starters are held on with the two nuts on the top engine casting and an L bracket on the lower crankcase.
MAKE SURE YOU DISCONNECT THE BATTERY FIRST OR YOU WILL LIKELY BECOME AN ARC WELDER!!!
John
