installing omc 400 series lower shift cable
Paul eagen
Does anyone have any tricks to get the shift cable through the intermidiate housing.
F14CRAZY
Ensign
Re: installing omc 400 series lower shift cable
Lube it up. Being that you don't want an oil that'll be hard on the rubber casing I used petroleum jelly. Ideally have someone else in the boat to pull it in while you push till its all the way in and you can get the retainer bolted
Boomyal
Best would be a silicone lubricant like you might find in a plumbing store. (not spray silicone). Petroleum Jelly is just that, a petroleum product that can be hard on soft parts. You shouldn't have any trouble getting the cable itself through. The only resistance point should be the molded, ribbed plug that is affixed to the cable.
You also want to clean out the passageway, in the intermediate housing. I use a brass 20 ga shotgun bore brush. You can get enough corrosion/gunk build up in there to make it difficult to pull that plug in.
F14CRAZY
Ensign
ooops...I always figured it was safe...
Boomyal
KY Jelly, imo.
Yep Howard, that should do it. On the other hand, re-reading the OP's post, does he mean how to put the cable in OR how to pull it out, thru the intermediate housing. That could be extraordinarily difficult. My local OMC guy has stated that on ocassion, he has actually had to cut the cable.
EDIT: Duh! I just re-read the title of his post. It clearly stated 'Installing'. That should be a breeze compared to pulling one out.
Nivekt
Yeah, a good water based lubricant will put it through no problem. I use Astroglide. It's so slippery I get excited! :)
Paul eagen
Thanks for all the help guys. I took it apart two years ago and dont remember having this much trouble getting it out. will try some if the suggestions tommorrow. Thanks again.
Howard Sterndrive
by "through" ^^ I thought he meant getting it in. Thread title says "installing cable".
To remove- Lots of penetrating oil - any flavour, just wash it off after. 1 Person pulling and 1 person pushing from the inside. And don't forget to unbolt the clip that fastens the cable to the intermediate on the outside.
