Installing Starter on Evinrude 25
rick_l
I have a 1977 Evinrude 25 hp. I want to install a starter and bracket on it. Someone told me that the starters and brackets are interchangeable for Evinrude up to a 35 hp motor. Is that true? Also, does anyone know the year range that I should look for.
DHPMARINE
Re: Installing Starter on Evinrude 25
20 thru 35 HP kits from 1977 thru 1987 are the same part number.
DHP
bertsboat
Re: Installing Starter on Evinrude 35 1978
I bouht a starter bracket and starter but it looks like there is too much space in the mesh of the gears. Is there an adjustment there to bring the starter closer?
CATransplant
You need to post a new thread about your problem, and identify your outboard by model number, then explain what it is you've done and are doing...exactly.
Adding a post to a three-year-old thread and not supplying the basic information we need will not result in answers that will help you.
