sportrider
Thread starter- Joined
- Jun 4, 2014
- 129
when installing stringers is it acceptable to use liquid nails or some other construction adhesive to attach the stringers to the hull?
so you might wanna do what YOU thinks best!!!when installing stringers is it acceptable to use liquid nails or some other construction adhesive to attach the stringers to the hull?
Would a manufacturer use PL?
I think the worry would be creating hard sports. Have a look here
PB is pretty easy and relatively cheap.
More than not, the factory doesn't bed them at all, they preconstruct the grid, lower it into the molded hull, and throw roven and poly over it all...
Like he said, very few small boats get any kind of bedding, even larger ones may just have the stringer spaced off the hull slightly so only the glass comes in contact with the hull. What it comes down to is it really doesn't make much of a difference in how it's done on small boats.
