Instructional video on Mercruiser 3.0L Alpha I Gen II bellows install
millenium3
I took the time to make an instructional video and wanted to share my experience and get some feedback from the community. I've already posted the video on YOUTUBE but if there is anything horrible concerning I can update the video. I'm pretty sure it's helpful enough to get someone through the process successfully...I did. Take a gander and let me know what you think.
http://www.youtube.com/watch?v=Ahtxll9Rma8&feature=g-upl
BajaDan
Re: Instructional video on Mercruiser 3.0L Alpha I Gen II bellows install
The audio portion is very weak and the camera view is kind of narrow. Content is ok, but I couldn't decipher all the audio. BTW, I just finished doing the bellows change out on my '92 Baja 3.0L Alpha I Gen II along with the gimbal bearing replacement and alignment. Good luck...
79Merc80
My Mechanic said that it's much easier to connect the bellows to the gimbal housing first, then to the transom assembly. The reason being is that since the gimble housing isn't attached yet, you can get your hands inside, once that is done, you can easially attach it to the transom end. Without the need or the time it took to make the helper tools.
Hope this helps.
Craig
Pete104
Hope this helps.
Craig
Why would anybody start with u-joint bellows installed on the bell housing first?
Hey Millenium, there isn't anything of benefit with that video!!!
millenium3
Well...I was hoping for constructive criticism so thanks BajaDan. I am sure there are easier ways to do this daunting task and if you?re a professional mechanic you might have found a preference in which you do the job.
As far as the "benefit" of the video, I found myself needing to replace the bellows on my boat. I have this much $$ and a marine mechanic charges this much $$$ to get the job done. I did a little homework in order to see if the job is possible for the "first timer" and I find YouTube a valuable source of education in several other projects I take on myself.
If someone needing to perform the same job in in my position, these are the benefits they might find watching the video:
-Proves an ordinary guy can accomplish this task in the garage.
-Gives an order of sequence in which the components are installed that clearly works.
-Gives an idea of what kind of tools are going to be required to perform this maintenance.
-Proves the maintenance CAN be done without the ridiculously priced Mercruiser tools.
-Shows there are some other required maintenance you must perform in order to accomplish the job and gives the viewer another idea of what the cost of this project is going to be.
-Shows the viewer a proven method of installation with handmade tools that require a little ingenuity but makes the hardest portion of this particular job easily performed and saves the individual from having to brainstorm to come up with said tools.
These are just a hand full of "benefits" that are coursing through my mind at the moment. Can you image if there were an instructional video for every task you needed to perform but have never done before? It would make being a boat owner a hell of a lot easier ;)
My goal in putting the video up in a boating forum was to have some experience take a look and let me know if there was any blatant disregard to a specific step that I could include in the video to help the "first timer" out a bit in his venture into a project not worth spending $4-500 if its something one can do themselves.
My total cost out of pocket came to about $200. I was quoted close to $500 in parts and labor depending on how good of shape the outdrive and gimbal housing/bearing was in. I am confident in saying the $300+ I saved myself was worth the time I put into the project. I'm hoping the video I made will give the next guy the same confidence.
Dshow
I plan to tackle this job in the off season for the first time so I enjoy seeing how other's have done it... Thank you for sharing! One thing I learned from the video is that you spent some time (and frustration) on making a tool to install the ring that holds the bellows, I spent the money for the tool and I'm guessing I'll be glad I did. Thanks again.
Fishermark
I watched the video and frankly appreciate the effort. I would disagree that there was nothing of benefit to the video - not sure why that was even posted. I have never messed with a gen II, so can't really comment on the procedure... but I appreciate you sharing it with us. Even the ideas that didn't work!
Oh yeah - welcome aboard! ;)
