Celebrity240
Thread starter- Joined
- Mar 26, 2009
- 33
Hey does anyone have the step by step instructions to changing the upper bellows?
This is the email i got from my buddies mechanic, make sense??
We removed the outdrive from the back of the boat to inspect the lower
exhaust bellows that you aksed to replace.
We found the gimbal bearing almost seized because the upper rubber boot had
water in it causing the bearing to begin to seize.
We added grease to the ujoints and the ujoints are fine.
We will need to replace the upper bellows. In order to do that, we need to
remove the outer gimbal "helmut" disassemble it, install new bellows and
reinstall it.
Since we have to take the gimbal apart, we would replace the shifter cable
as well, the gimbal bearing and the seal
Here is the cost:
* Labour $783.20 (8.8 hours)
* Parts $295.00
* TOTAL $1078.20 PLUS TAXES.
reinstall it.
Here is the cost:
* Parts $295.00
