Intake manifold gasket removal?
SharpeCon
I am replacing the gasket on my intake mani. I am wondering the old one is really stuck on there, do I need to get every little speck of the old gasket off and down to the nice shiny mashined edge? I took a razor scraper and got 97% of it off, and it is nice and smooth. Is that good enough?
Thanks
Bifflefan
Re: Intake manifold gasket removal?
when you rach 100% then your done.
If you leave it one there then what was the point of doing the job.
As i read on someones Signature
"Why is there never enought time to do the job right the fist time, but there is always time to do it again?"
SharpeCon
How would you remove the last 64th of an inch of the gasket? It is only on certain parts of the gasket area that remains....?
TowRoper
ive used emery cloth with no problems. but do get it all off so it wont have a spot to leak, lean fuel mix not worth the risk in my book ;)
SharpeCon
Razor blades. Get some gasket remover spray to make you job easier.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=8621
I did get some gasket remover and emery cloth, it is working great now! Although it is scrathing the surface a bit, very minor scrathing. That ok? I did pick up some spray adhesive for the gaskets, the guy told me it would fill in any small imperfections. He said it worked great on his gaskets when he rebuilt his engine.
SharpeCon
I did get some gasket remover and emery cloth, it is working great now! Although it is scratching the surface a bit, very minor scrathing. That ok? I did pick up some spray adhesive for the gaskets, the guy told me it would fill in any small imperfections. He said it worked great on his gaskets when he rebuilt his engine.
TowRoper
hiya, use a little less elbow grease and you will be fine;) you want to get the gasket not the metal lol
SharpeCon
LOL! gotcha! The gasket on the block is next so I will use a little less elbow on it....
TowRoper
i know you know this already but ya want to make sure not to get any crud in the block or mani, i cut cardboard plugs to fit the port then shop vac it out but i had a bad experience not keeping it clean enough lol i learned fast that clean clean clean is the best way. good luck mate!
Ayuh,... It's gotta be 110% Clean..... 'n Flat....
Try a Scotch Brite Pad instead of emery,... It's not quite as aggressive...
Or use finer emery....
dr_bowtie
I use a scotch brite pad on an air tool....they have those at almost all local home depot stores and Menards and Lowes...in the drill bit sections...you can use it in a drill to...cleans the surface very well...
