Intake Manifold Question
Quarterwave
Hi everyone,
Can anyone advise what this inlet is for on my Edelbrock intake manifold? (please see pic for reference).
Thanks!
harringtondav
Beats me, but my guess it's for a bimetal thermal choke spring housing. It looks like you have an electric heated choke control. So you may be able to just cover it with a gasketed plate and move on.
Bt Doctur
you have a automotive intake manifold that uses a EGR valve. Marine engine dont use that so just block it off or get the correct manifold for your application
EGR cross-over. get a block-off plate
dan t.
All wrong answers, its for a external choke, a heat pipe will bolt directly in that hole or there is a block that bolts on to mount a bimetallic spring thermostat. Just make up a plate to cover it, seal it to the manifold with Permatex Ultra copper high temp silicone.
Bt Doctur
with the electric choke on the carb, the heat stove would be useless
but I would have used this one
