HorizonblueDK
Thread starter- Joined
- May 27, 2010
- 355
I'm preparing a friends 20 footer for the season. It is still on land. The engine/drive is a mix of Mercruiser and Volvo Penta.
Engine:
4.3 V6
4 barrel Rochester
Thunderbolt 4 ignition
Crank driven raw waterpump
Fresh water cooling
Outdrive: Volvo Penta 290
This setup ran great last year.
When I startede the engine the first time a couple of weeks ago, a valve was stuck. I could hear that the engine skipped a cylinder, when I was turning the key. And when it startede, it definitely ran on 5 cylinders only. I have since then started the engine a number of times, for a limited time, since I don't have access to a garden hose, where it is now. The impeller is not installed yet, so no damage to the raw water pump.
The last couple of times I've started the engine, it fired up on all cylinders and ran great for a short time. Then it started to stumble, like it lost a cylinder again. When I give it a little gas, the stumble goes away, and the engine seems to run fine again.
At this time I have to stop the engine, cause I feel it's getting warm. So I don't know what will happen, if I let it run.
When I start the engine 1/2 hour later, the same again; starts and runs fine, but then begins to stumble. A little gas and it seems to run fine. Then I have to stop, again because of rising temp.
I would like to find out, if there is anything wrong, before I move it.
So my question is:
Can I rule out that there still is a valve problem, is it a carb issue then?
Engine:
4.3 V6
4 barrel Rochester
Fresh water cooling
So my question is:
