'89 Evinrude 175 Crossflow
My 175hp feels like it is taking off in fourth gear. It will eventually plane out and run at around 4800 RPM at WOT but not at the 5500 RPM that it used to run. What is interesting about this problem is that if I kink the fuel line (essentially shutting it off) while trying to take off, the engine will really come alive for a couple of seconds until it runs out of fuel and dies. I kinked the line just on a hunch because of how fast the engine died when I tried pumping the bulb while trying to get moving.
Since this issue has started, I have replaced the fuel pump and rebuilt the carbs. All float levels are 1" from the carb to the lowest point on the float as it shows in the manual. None of this has changed the performance at all.
It is also worth noting that the plugs don't appear to be wet.
I am at a loss as to what to try next. Any ideas?
Thanks,
Thanks,
