Last year, I decided to get rid of the worn out shredded carpet in my Blue Wave. I purchased and applied a coating called Durabak. Initially, the boat looked great, and I was completely satisfied with the material. The color and finish was very nice for a relatively inexpensive D.I.Y. coating, as seen below:<br />
<br />
<br /><br />My boat is garaged, so sunlight and weather didn't get to it unless I was fishing.<br /><br />Well, during my first trip to the TX coast, less than a week after applying the coating, I had to store it outside for 3 days while we were there. Through that time and the time while we were fishing, the blue coating faded and turned a 'torquise' color. I thought it had to do with dust build up, salt water, dirt, etc...until I took it to the car wash and I noticed that the color of the coating would rinse away at a car wash, leaving just the rubber granules on the boat.<br /><br />Come to find out, Durabak sent me the NON-UV resistant blue, and the UV resistant white. Neither one of their gallon cans says UV/Non-UV, so I had no way of knowing. When I called them back to discuss the problem, all they wanted to do was sell me new UV-Resistant material at original cost. I was even more fed-up when I saw the original receipt showed UV Resistant for BOTH gallons...so they shipped the wrong stuff.<br /><br />So, I've now got decks that are part torquise, part bare resin and a white floor.<br /><br />The white floor is holding it's color well. It is just dirty in the pics. There is only one spot where I dropped the anchor and hit it on an angle where I managed to chip the coating...other than that, it's in good shape. I did notice that this material seems to be nothing more than a hard epoxy paint with granules mixed in...because once you walk on it long enough the color wears off and the rubber granules come through.<br /><br />Needless to say, I don't want to spend the money to re-do the boat with Durabak. I can't say I'm un-impressed with the white floor, but I can't stand to look at the faded/blotchy blue decks and sides any longer...and I'm un-impressed with the service I received on a mis-shipment.<br /><br />Here are a few pictures showing the 'AFTER'. Please note that this boat is stored in-doors and sees sunlight only when it's on the water. Note the areas where you can see fibgerglass through the blue coating (which was 'thick', 2 gallons worth...3 coats). Please excuse the messy boat...I am dismantling it, AGAIN!<br />
<br />(click the pic for larger version)<br />
<br />
<br />
<br /><br />So, here are the two options I'm considering:<br /><br />1) Have a professional Bedliner sprayed into the boat. Same bedliner I've got in my truck...excellent product ($700 through a friend who works for the company). The prep is easy, it will basically stick right on top of this durabak because it is so rough and porous. Just a good cleansing and a scuff with 40grit in corners, and it's good to go.<br /><br />2) Remove the durabak, and GelCoat the interior with a splatter type finish like they come with from the factory. I have never applied gel coat, but I am an avid automotive painter and I assume it could not be much more difficult than laying a set of flames on a 32 Ford. My main concern here is cost. What does gel coat cost? Could I do the interior of a boat fairly cheap?<br /><br />I'm considering the gel-coat option. I assume that I could do it for less than the bedliner, and It would be more 'factory' appearing. I'm considering trading the boat for a larger model in the near future...and dealers seem to be a bit leary of any type of aftermarket paints/etc. <br /><br />Thanks for looking. Let me know what you think.<br /><br />And if anyone has questions on Durabak, feel free to email me.<br />S_Queeney@hotmail.com<br /><br />ShawnQ
