Hi guys, got all prepped last night for priming/painting, everything is all laid out and going to do a two part brush clean up so have containers full of brushing liquid where I will dip the brush in one can and immediately place in another can.
Needless to say I am going to go through quite a bit of brushing liguid 333....I read the MSDS sheet as well as the data sheet for this liquid and basically it is just 50% Kerosene and 50% Aliphatic Naptha so thinking I will only use the brushing liguid 333 for surface wipe down and thinning the paint if required.
For brush clean-up and etc....thinking I am just going to make a mixture of kerosone and naptha which both are readily available and be way cheaper.
What are peoples thoughts, sure Interlux is just purchasing readily available chemicals and mixing versus a unique proprietary chemical all there own.
