Intermediate Bearing question?
bransjeep
i have the model that uses 2 bearings in the housing..the parts dealer at Marine Specialties couldnt find the part numbers so i did some research... i believe i need either a # 6007 bearing and a # 6206 or two #6206's can anyone please confirm this?
captmello
Re: Intermediaate Bearing question?
Your info is very limited in your post. Are you talking about a DP-A outdrive???
If so, here is the parts breakdown, # 86 and 89 are the bearings. You'll also need two #85s.
http://www.volvopentastore.com/Connecting-Components-Drive-Sp-A-Sp-A1-Sp-A2-Dp-A-Dp-A1-Dp-A2/dm/*******.500781638--**********.225273434--store_id.366--view_id.767429
bransjeep
Thanks and, for future i will add much more needed information, it is a DP-A drive and i have it apart now, i believe the bearings are just 6206 bearings, i was wondering if anyone had done this and new if that was a correct cross reference?
