Augoose
Thread starter- Joined
- Mar 21, 2010
- 1,245
This is a Alpha 1 on a '89 4.3 Mercruiser.
Sorry if this has been covered before, but after searching, I wasn't successful in finding a solution.
We were out today and everything was great for a couple of hours. We went tubing and skiing for about 30 mins or so and after the first tube went around we were idling for a second when I noticed a vibration and a dull "bump, bump, bump, bump" coming from what I believe was the lower unit. Almost felt like an out of balance drive shaft in a truck. We immediately shut down thinking the prop was bumping off of a submerged log or some other obstruction. I dove down under the boat - nothing there. No line wrapped around the prop and it spun freely when placed in neutral. Unsure of what happened, we started it back up and slowly idled around with no sound nor any vibration. When the bumping and vibration occur, its a very heavy bumping and vibration if you can imagine that. Its not a sharp bump or a knock - it really feels like the propeller is slowly hitting a old rotten log under water is the best way I can describe it.
Everything was good for another 10 minutes or so of tubing / skiing when once again while idling around, the vibration came back along with the "bump, bump, bump, bump" sound. The sound was quick, about 4 bumps per second and it really felt like we had run aground in soft mud and the prop was just bouncing (we were in 100+ feet of water). Again, immediately shut down, pulled the dog house and looked for anything obvious - nothing.
Concerned, we slowly drove back to the dock, a 20 minute trip. No noise, no vibration, nothing - even changing speed and turning back and forth the whole way back to the dock. As we approached the dock and we slowed down to idle, the vibration and bump sound came back. Even in reverse, it made the same bumping sound and vibration. After about 5-6 seconds, it went away on its own. I put the boat on the trailer and took it to the house to inspect it.
The gear oil has been checked recently, full level, no water in it, nothing abnormal. The engine temp was steady at 150 degrees or so. The prop spins normally in neutral, ratchets when you turn it in gear one direction and locks if you try to turn it in gear in the other direction, doesn't feel like it has any abnormal play if you pull it forward and back, and at speed the boat feels and drives normally.
Recent service at the start of summer included all new bellows, new gimbal bearing, new transom seals, lower shift cable replacement, and that's about it. No leaking fluids that I can see.
I'm very careful to only operate the boat with the lower unit all the way down so as not to stress the u-joints, but could that be what my problem is?
I have the boat in the garage in hopes of identifying the issue tonight before labor day arrives.
Thanks!
Thanks!
