Intermittent Alarm
FreeBeeTony
Have twin '95 175 Johnsons, VRO's are intact.
Have an intermittent alarm at idle on port engine, in gear or in neutral. Just 1 short beep, not cyclical....totally intermittent and only at idle, both engines idle ~600-700RPM in gear. Otherwise engine runs great.
Took the hood off and looked behind the air silencer, a small amount of oil/fuel, nothing abnormal.
Did notice a slight sneeze every once in a while. Would a lean condition cause an intermittent alarm?
Could be the FUEL RESTICTION alarm.----Test run with another ( portable ) tank and hose.
dingbat
Had a similar issue running off the reserve tank when low on fuel. Seemed to worsen when fuel was sloshing around in the rough.
Changed the fuel lines (tank to fuel pump) and tank selector valve...........problem never came back
FreeBeeTony
Thanks, maybe I will try running that engine off the aux tank.
BTW.........if it was a fuel restriction issue, would it be more evident at higher RPM's?
dingbat
In my situation, it seemed to manifest as a leak (vacuum) instead of a restriction (blockage).
Don't remember it happening while running. Always trolling which lead to the vacuum leak theory
??----If there was a leak it would not trigger a fuel restriction alarm.
dingbat
How might one check for a vacuum leak?
You need a vacuum tester
For me, it was a good predict to change out the 8 years old fuel lines on the boat. In the process found a suspect oring in the tank selector valve. No problems since
dingbat
I always wondered about that.
What mechanism is used to detect a restriction?
System would need to monitor flow, vacuum or the lack there of.
There is a switch between the fuel pump and fuel tank.------When fuel is restricted it sounds the alarm.
Terrapin
You can test the fuel restriction alarm by simply putting a kink in your fuel line. This will give you a continuous alarm until you release the kink.
dingbat
Found what I was looking for....
1-4 hg. (0.49 to 1.9 psi) Is normal operation.
Switch alarms at 5.5 hg. (2.7 psi)
my reserve tank
15’ of 3/8” fuel line = ~1.5 psi
16” head (empty) = ~0.4
Racor separator filter, clean = 0.6 psi
Clean system drop = 2.5 psi
Not much room to play with. A dirty filter or a “sticky” anti-siphon value could put you over the edge
