DunbarLtd
Thread starter- Joined
- Nov 8, 2016
- 357
Hello all, I am working on 1988 85hp.
I've been enjoying the summer and fall out here in the west (USA) with minimal issues. Although, I still have some Im chasing down.
#1. I still experience a "cough" when cranking. It sounds like a big HISS or PSSHHH for just a second and then the motor stops cranking instantly. Cold or warm doesnt matter. It is completely random as well. Sometimes it cranks perfect and fires right up (only after warm). Starting cold it seems to cough more. Choke or no choke. Even if I give it gas by pushing in button on throttle handle. I always make sure to squeeze the primer bulb. It stays firm.
#2. Not sure if the cough is related but I have pretty good shaking of the motor when going maybe 5mph. It rattles the glass on my bayliner. I have it set to idle around 3.3mph at about 700rpm i believe. At that speed it shakes but its gets worse until maybe 10ph or so.
Ive checked static timing and it is 28btdc
I have all 3 carbs air screw set to 1 turn out.
Carb bowl floats are brass and do float as ive tested in gas. They are set to parallel. I installed a repair kit with new needles and tested to make sure they dont leak.
I have replaced all fuel lines and fuel pump diaphragm.
Also replaced base gasket and stopped exhaust oil leak.
Also replaced all 3 coils with new wires. This fix did not fix the issues.
Compression is around 130psi on all 3.
Ive done a link and sync many times.
Ive sprayed starting fluid everywhere around the intake and the motor will still shake and idle does not change up or down.
I get to 4400-4500 rpm full power and I had it going 35mph last week. So it seems to have worked itself out for some odd reason where I had a previous issue with wot speeds.
So now I would like to figure out why it is coughing and shaking.
I do notice (by sound) it seems to have a slight miss as well when in gear at idle speed.
I have been out by myself every trip so I cant really use the timing light while in gear.
Any help is appreciated. Thanks.
- Mark
- Mark
