chconger
- Joined
- Jul 3, 2012
- 315
Hi
I have just replaced my ESA to find it behaves as the old one. Basically when i manually depress the normally open switch that rides the cam, it does not stumble the engine reliably. It probably stumbles the engine about 10% of the time. I have gone over the wiring and confirmed continuity, confirmed a good solid ground, and confirmed the switches are operational.
I am idling at about 500RPM...tried varying that with no effect.
There is one clue left here;
With the ignition in the "on" position, and the engine not running, the "switched 12V" Violet wire is not coming in to the ESA at 12V. It's reading 10V The battery itself is strong and well above 12V at the terminal posts.
Now I understand that this line goes to the ESA and splits on to the ballast resistor wire and then to the coil primary. And in the condition i am describing (ignition on but not running) there will be current flowing through the primary. But at the point of the ESA input, I should expect 12V there correct? The voltage drops will occur along the ballast wire and the coil itself.
Could it be that I have a something providing resistance upstream towards the key?
Would 10V at the ESA be a problem, or is there an expected drop in V prior to the ballast wire?
Thanks Much
Chris
Thanks Much
Chris
